Picklist Sets
Picklist Sets are a Configuration tool for creating a filtered collection of picklists for use in specific projects. For example, certain projects might require specific picklists to be only used so it would be useful to only display those picklists required for that project and filter out the ones not required.
Some initial considerations are that only one Picklist Set can be used per project and that, once a Picklist set is applied to a project, it cannot be removed. Finally, Picklist Sets cannot retrospectively be applied to projects that have been already created.
