Use the Manage Units section of the configuration tab to access to the Picklist configuration manager to allow for editing the availability of lists. This can be done either within a project (as shown below) or as described in the Introduction to Configuration Packs section below.
Further Information on managing Units can be found under the Units section of this guide.
