Configuring the Model Structure
Use the Model Structure section of the configuration tab to access to the data dictionary to allow for editing the actual data structure database. This can be done either within a project (as shown below) or as described in the Introduction to Configuration Packs section below.
Further Information on configuring the Model Structure can be found under the Data Dictionary section of this guide.
