Configuring Template Images
On most of the templates that are held within the system, there will be place holders that allow for images to be placed on the logs and sections. To edit these, select the Template Images option from the configuration section of the ribbon. This can be done either within a project (as shown below) or as described in the Introduction to Configuration Packs section below.
The template images window will then appear showing a summary of currently used images on the logs.
To change one of the images, just press the Edit Button next to the value and browse through to the new required image. We recommend that a bitmap file is used. To delete the stored image simply press the Delete Button.
The company logo which appears on template output is generally defined by the "Logo1" image and so obviously this will need setting at least once for commercial use. The image should either then be changed using the edit button for the Configuration Pack (to standardise the logo) or else removed altogether from the Configuration Pack. The latter approach will then allow "Logo1" to be defined on a project-by-project basis.
