By default, when a quick log is produced, the default template will be loaded for the selected location. This default template can be edited to allow for the correct template to be loaded when needed. To change the default template for a location type, currently only possible from within a project, select the Default Templates option from the Configuration tab on the ribbon.
The Default templates window will then appear with a list of all the known location types currently listed in the system. To change a default template, select the drop-down list next to the location type that is to be changed, then select a new template from the list.
Templates can be changed on the fly by changing the current template when a quick log is shown on the screen.
