The Pack Options button allows for the setting of the format of dates and numbers etc. that will apply to all of the projects that belong to this configuration pack.
Date Settings
The following settings will effect how the dates will be presented inside projects that belong to this configuration pack.
- Date Format - Allows for the setting of any fields that are strictly date format (such as Checked By date in the Location Details table)
- Time Format - Allows for the setting of any fields that are strictly time format (such as Time Elapsed in the Progress by Time table)
- Date Time Format - Allows for the setting of any fields that are date and time format combined (Such as Date Time Started in the Location Details table)
Number Settings
The following settings will effect how the number values will be presented inside of projects that belong to this configuration pack. A preview of the applied values is presented in the Example at the bottom of the form.
- Decimal Seperator - Allows for a character to be placed in between integer and decimal values.
- Digit Grouping Symbol - Allows for a character to be placed in between the values selected in the following Digit Grouping option.
- Digit Grouping - Allows for the selection of when the previous Digit Grouping Symbol character gets inserted into the number string.
