Exporting a Configuration Pack
You may wish to use an existing configuration pack on a different database. To do this you can export the chosen configuration pack easily.
To Export a chosen pack, select the configuration pack and then click the Export Pack button under the configuration tools menu.
Click the magnifying glass icon to bring up the save file directory window to name the pack and select a save file location.
After choosing the name for the pack and the location press Export.
The pack is stored as a.hbp file in the chosen directory this file can then be imported into the chosen database by selecting create a pack and choosing the file. See crearting a Configuration Pack for more information.
