This section covers how to create and edit tooltips on map features. Any imported data set can have tooltips added, a tooltip being an item of text displayed when the Mapping | Pan and Tooltip button is active and a feature on the map is clicked.
The various settings that can be assigned and altered in creating tooltips are arranged in sections:
General information on the order and name of the tooltips
Press save to commit the changes and update the map.
The commands in the bottom left of the screen can be used to create, copy and delete extra tooltips.
