Edit a Map Line Style
This section covers how to edit and style basic Line styles, how to create creating condition styles is covered in Creating Conditional Themes on Mapping Datasets.
The various settings that can be assigned and altered in editing a Line style are arranged in sections:
Legend
The Legend section has one entry; it is used to specify the label used for the layer in the Map Legend.
Label: Enter the text for the legend label
Condition: See Creating Conditional Themes on Mapping Datasets section.
Stroke
Defines the line properties.
Zoom level
The zoom level in the style manager gives extra control over the zoom ranges the features are displayed. The allowable minimum and maximum levels are defined by those given for the dataset when imported, but within this range the levels can be further control.
Save
Press save to commit the changes and update the map.
