Log Production
The Log Production section of the tab allows for any selected location on the map to have a quick log generated. Simply select the locations on the map using the selection features and then select the Quick Log option. If more than one location is selected, then the Log Report option can be used. For more information on producing Quick Logs see the Quick Log section of this user guide.
