Coordinate
Use the quick 'zoom to' functionality to focus and increase magnification on any location on the map, using any currently defined, active coordinate system.
If a coordinate system is needed that is not listed inside of the Manage Co-ordinate Systems option in the System ribbon, then check the coordinates section of the Bentley KnowledgeBase. Further systems are available on request to support@bentley.com.
Simply, select the required coordinate system from the top drop-down list, then enter the eastings and northings either via typing in the values or using the sliders, then hit Go to. The mapping will then refocus centrally onto the specified coordinate.
If the required coordinate system is currently not available, check underneath the Manage Coordinate Systems option in the System ribbon.
