Navigating the Map
The mapping interface can be navigated using the keyboard and mouse. To move the mapping around simply click anywhere on the map, then drag the mouse around. The map can also be zoomed into and out of by using the scroll wheel on the mouse. The map can also be 'nudged' around using the arrow keys on the keyboard.
