@mis
OpenGround Cloud Professional allows for users to connect through to the @mis data service directly from OpenGround Cloud Professional, which allows for users to add and view their data directly without the need for an AGS Import / Export.
When adding a new test schedule to a project, simply select the option for @mis from the Schedule Type drop-down. When selecting Next, a dialogue allowing for a user to connect to the service will appear.
This will then update to allow for a Client, Project and an @mis Chain Of Custody to be entered.
An @mis window will then appear within OpenGround Cloud Professional allowing for data to be entered using the @mis service.
