Creating Schedules
To create a Schedule within OpenGround Cloud Professional, select the Create Schedule button from the Testing section of the Scheduling ribbon.
The Create Test Schedule form will then appear allowing for a new schedule to be created and detailed.
Enter all of the required data into the relevant fields and select the Next button. Note that the Schedule Type and the Schedule Reference sections must be completed before the next stage of the process.
On the next stage of the wizard the Manage Test Schedule appears which allows for the samples to be selected and the relevant tests assigned. More information is shown in the Assigning Tests to a Test Schedule section below.
To enter an @mis related Test Schedule, select the @mis option from the Schedule Type drop-down.
Details on adding an @mis related schedule is detailed below in the @mis section.
