Adding Chain of Custody Data
To add a Chain of Custody to a project, open the project within OpenGround Cloud Professional and select the Create button from the Chain of Custody section of the Scheduling tab.
The Chain of Custody Samples form will then appear. This form lists all of the samples that are currently in the project in the top of the form and all of the samples that are in the current chain of custody at the bottom of the form.
A reference must be entered at the top of the form to enable for the chain of custody to be saved. Select all of the samples that are to belong to the chain of custody and select the Add Selected button to add them to the list. If all of the samples are to be added then the Add All button can be used.
Further details regarding the chain of custody can be entered by clicking the Details button at the bottom of the form.
