Importing Laboratory Test Data from KeyLAB2
It is possible to import any of the test definition files from KeyLAB2 into OpenGround Cloud Professional. A test definition file will store all of the data relevant to the test and populate the test grid with this information.
To export all of the tests from KeyLAB2, select the Sheets option from the Configuration section of the ribbon. The Test Definitions dialogue will then appear.
Simply select the tests that are to be exported from the left-hand side of the window, then right-click and select Transfer – Export.
It is possible to select more than one test by dragging over a selection of tests or shift selecting multiple tests at once.
To Import this data into OpenGround Cloud Professional, select the KeyLAB Import button from the ribbon.
Select the Labatory that the tests will be associated to in the top drop-down list, then select the browse button to select a file that contains the test data.
Select the import button, then all of the test data will be imported into OpenGround Cloud Professional against the relevant laboratory.
