Adding Tests to a Laboratory
OpenGround Cloud Professional allows for a list of all of the tests that a laboratory can offer which can then be used within projects.
To view all of the currently listed tests that are stored against a laboratory, select the laboratory from the Laboratory information tab as listed in the section above and select the Manage Tests option from the ribbon.
A list of all of the currently stored tests against that laboratory will then be displayed.
To add a new test to the list manually, select the Add Form option from the ribbon. The Add form will then be displayed.
Simply enter all of the required data into the form and select the Save option to add the test information to the laboratory.
