Editing Laboratory Information
To edit any of the information regarding a laboratory, select the Edit Form option from the ribbon.
Simply enter all of the required data into the form and select the Save option to add the laboratory information to OpenGround Cloud Professional.
It is also possible to change the data inside of the grid within OpenGround Cloud Professional by selecting the Add/Edit Data option from the ribbon.
