Adding a Laboratory
To browse through to the laboratories currently stored within OpenGround Cloud Professional, select the Manage option from the Manage section of the System ribbon.
A list of all the current laboratories that are stored on the system will then be displayed.
To add a new laboratory to the list, select the Add Form option from the ribbon.
Simply enter all of the required data into the form and select the Save option to add the laboratory information to OpenGround Cloud Professional.
