It is also possible to create a location group directly from the ribbon interface. To do this, select the Data tab from the ribbon and then select the Location Groups option.
The Location Groups option displays all of the location groups currently defined within the system.
Select the Create Button to add a new Location Group.
Enter the name for the group and click save.
The group will then be added to the interface and will allow for use with filtering of other grids as well as other uses.
To start adding New Locations click the locations button which will bring up the location group locations interface.
The interface is straightforward and shows all the locations contained within the locations grid. To add a new location simply select one and click Add Selected. This will move the Location from the top grid "All Locations" to the bottom grid "Locations in Group".
You can continue to select from the list individually or you can use the same filtering technique to filter locations you wish to add and select Add All.
The above illustrates adding all locations based on a filter of all locations starting with BH. Click Close when you are finished.
