Creating from Map
A selection of location data from the mapping interface can be used to create a location group by following the steps below;
This technique can be used in a variety of ways to manipulate the data in the database.
For example, if a client wanted just the geology records for holes inside a specific section of the map, a selection could be made then the Geology Records table opened with the map selection filter applied.
