To create a location group from a data grid follow the steps below:
- Filter the data grid to only show the data you wish to be included in the group. More information on filter data grids is included in the section on Filtering Results.
- Select the Location Group option from the context sensitive ribbon.
- Enter the name for the group and select Save.
Note the text in the window that tells the user how many locations will be added to the Location Group.
- The group will then be added to the interface and will allow for use with filtering of other grids as well as other uses.
