Users withOpenGround CloudProfessionalAdministrator level can restrict the type of files that can be uploaded and can also restrict the file size of each type of file using the steps below.
Select the File Extensions Icon on the main System Ribbon.
Using the Manage File Type form (show below) it is possible to add new items and edit or delete existing items
