KeyLogbook Import
The Data Import wizard allows you to import Keylogbook files in the same way as standard AGS importing with the extra facility to import the zip file generated from the Keylogbook file exporter. The Data Import wizard has KeyLogbook mapping set up by default.
The below steps with instruct on how to import the zip files once they are saved on your machine's directory.
Inside the created project, select the Data tab and choose Import Data.
Select the File Format as KeyLogbook and the Mapping as Default.
Click Add and select the directory with zip files. There may be many files you wish to import based on log shifts recorded so select the ones you wish to import and click Open The files should be displayed in the wizard when ready to import select Next.
The wizard will check the files for errors or warnings which if any are reported can be viewed by clicking on the warning link.
Press Next to start the import and Click through the Import wizard until you see the Plan stage.
The Plan will confirm the additions/updates to be added into OpenGround CloudProfessional. Press next to commence the Import proper.
The Import should complete, and the data will now show in OpenGround Cloud Professional.
