Managing AGS Imports
You can keep track of AGS data being imported into each project using the Manage Imports facility. The tool provides grid data which can be filtered if there are multiple imports into one project. The grid contains the following items:
To check the Import History by following the steps below:
In the project select the data tab and click Mange Imports to display the Import History Dialog window.
The Import History dialog will display all the imports into this project. If you wish to download the AGS files then press the Download button by the appropriate file.
Choose the directory for saving and press OK.
