To view the current list of snapshots currently listed in the system, select the Manage Snapshots icon in the ribbon. You will then be presented with the Snapshots window.
From within this window you can see how often the database has been backed up and also what kind of backup was taken along with any comments. The user who made the snapshot is also listed.
The latest snapshot being used by the system is the snapshot that is currently marked as being Active.
