Creating a Snapshot
OpenGround Cloud Professional will automatically create a full snapshot once a project has been created. This will act as a base image to allow for you to start over again if required. An incremental snapshot will also be created every time a data import is processed.
Only users with edit, data import or project manager rights have sufficient access to take snapshots along with System Administrators.
To create a snapshot manually, select the Create Snapshot icon on the project ribbon. You will then be presented with the Create Snapshot window.
From within this window, it is advisable to enter a relevant remark next to the Comment section to help identify the backup should you need restore it at a later date. To create the snapshot, select the type of backup you require and click Create.
