What Are Snapshots?
Snapshots are backups of the project database. There are two different types of snapshot, Full and Incremental.
It is recommended that incremental snapshots are used as the main type of backup. This will ensure that the snapshot process remains as fast as possible and also allows for more control when deciding where to restore to.
We recommend that a full database snapshot should be created on a regular basis. This should be after an agreed set amount of time or when major changes are made to the database.
