Delete Project
To remove a Project from the OpenGround Cloud Professional database, ensure no Project is currently open, select the Project in the Projects grid and then click the Delete Project button on the Grid Tools ribbon:
A dialogue will then appear to confirm that that the Project should be deleted.
When a Project is deleted, it will be moved to the Recycle Bin where it can be restored within 90 days. After 90 days, the Project will be completely removed from the database, and all data within the Project will be lost. We therefore recommend that some form of backup (such as CSV or AGS file export) are kept.
