To edit the details of an existing project within OpenGround Cloud Professional, click on the project name within the project grid to display the grid tools context sensitive ribbon. Then select the Edit Project icon.
This information can also be accessed from within the project itself. Simply click on the Project Details button from within the Project ribbon when inside the project.
The Edit Project window will then appear allowing for edits to the project details to take place. The edit project window contains the same properties and validation as the Create New Project window. For further information, see the Creating a New Project section of this user guide.
The Edit Project window also gives further information regarding who created the project.
