Project Navigation
To open a project within OpenGround Cloud Professional, simply double click on the project name in the project grid or click once then select Open Project from the Grid Tools Ribbon.
Clicking on a project will update the ribbon with the context sensitive grid tools section relevant to the project explorer.
Using this ribbon, the user can Open the Project, Zoom to the current set location on the map, Bulk Update any field within the project grid, Toggle which project is the current one, which moves that project to the top of the list, and manage the current access to the project for other users. Users can also change the currently set location for the project as well as editing the project details and deleting the project from the database.
Filtering and searching actions can also be done on the project list to help you quickly find the project you need. See the section on grids for further information.
