Adding Additional Fields to Project Grid
If there is a need to add an additional field to the project grid, then this needs to be done in a slightly different way than if this were to be done within a project or configuration pack.
Select the Project Setup option from the System Ribbon.
Select the Add Header option from the bottom of the window.
Note: If you wish to edit an existing header, then simply select edit after selecting an existing header and follow the same process.
The Add Heading window will then appear allowing for the parameters of the new field to be entered. Enter the values as needed.
Click the save button to make the column available.
Note the display order field. This value states where the column will appear in the grid (0 being furthest left).
By default, all OpenGround Cloud Professional grids will have integer values for each column (1, 2, 3 etc.). Therefore, if a column needed to be inserted between the 2nd and 3rd columns then a value of 2.5 could be entered.
The new field will now become available within both the Edit / Create Project window and also the Project Grid.
