Multiple Grid Filtering
It is also possible to filter all open grids with certain criteria. Towards the top left of the screen is the option to select a location (Or custom group) which will then update all open grids to only show values that match that data. Grids may need to be refreshed to ensure that the filter is applied correctly.
Groups can be added by creating location groups.
More information on groups can be found within the Working with Location Groups section of this guide.
