Grid Filtering
There is also the functionality to search and filter your data. To filter the data, just select the column containing the data and click on the filter icon within the header. The filter icon is the left most icon on the right-hand side of the column header. Clicking this will open up the filter options for that column.
Filters for a particular column can be cleared by selecting the filter option within the column header and then selecting the Clear Filter option.
Filters for all columns can be cleared by selecting the grid, then from the context sensitive ribbon, selecting the Clear Filters option.
