A powerful feature within OpenGround Cloud Professional is the ability to search for a particular table within the project explorer, allowing for quick identification of a required table when needed especially if the user is not familiar with the OpenGround Cloud Project Explorer tree structure.
This is located at the bottom of the Project Explorer tree found in the bottom left of the application.
The Project Explorer search function allows for a 'fuzzy' search of the project tree to help users find a particular table as fast as possible using only a part of the name of the table that may be known. The example below shows the search functions ability to find the SPT test results table just by searching for penetration. Entering the word penetration followed by pressing the return key gives the following results.
