Under the Title Group put a Title for the Table e.g. Casing (for displaying casing information). It is also possible to define the Title and Header heights. Below the Header heights there are the Borders and Title Style buttons.
Borders button (for everything): To set up borders (for the table, header and Data Columns) press the Borders button above the Columns box and selecting the appropriate values.
Styles (Title Style only) button: In order to change the Title style, press the Styles button above the Columns box.
