Range Symbols and Picklist Range Symbols are very similar so will be placed together in this guide. The goal of these items is to show graphical information on a template when a condition is met. These will have a top image, a connector image and a bottom image.
To insert a Range Symbol Object into a column, follow the steps below:
- Select the first empty box below the column headers that the item is to be added to.
- Double click on the Range Symbol Object in the Depth Related section of the left hand side tree view.
- The Range Symbol Object will now be added and the text "[RangeSymbol]" is inserted in the cell.
- It is then necessary to choose either a top symbol and a base symbol or a middle symbol. If a top symbol and base symbol is used, then a connector can also be used to join these up (like the standard water strike item does).
- Symbol Border- Options button to style a border surrounding the Range Symbol.
A Picklist Range Symbol works the same way as above but uses the images defined against a picklist that is stored within OpenGround Cloud.
