In this tab it is possible to select the limits for the bar chart.
A fixed bar height may be needed (this is usually used for Dynamic Probe Testing) and in that case check the Fixed Bar Height check box and add a value.
It is also possible to set the style by pressing the Style button that opens up a new window with two tabs: Borders and Background. This is the style of the bar itself, so the Borders can be changed e.g. set the border colour to red and/or change its thickness. In the Background tab it is possible to select a wide range of colours.
In the background tab it is possible to choose a transparency for the bar so that multiple bars can be shown on top of each other etc.
