Dynamic Text
A Dynamic Text item is used to allow for extra data to be input by the user when the log is generated. For example, it may be necessary for a user to type in comments about a section in the header area. These are used to populate the parameters in the OpenGround Cloud application when producing a quick section, quick log or site plan output.
