A point symbol object is used to display a symbol in the header. This can be used to show as a key item.
To insert a Point Symbol Object into a cell, follow the steps below:
- Select the cell that the item is to be added to.
- Double-click on the Point Symbol Object in the General section of the left hand side tree view.
- The Point Symbol Object will now be added and the text "[PointSymbol]" is inserted in the cell.
