Label Object
Inside a cell the simplest object that can be inserted is a Label Object.
To insert a label object into any cell simply select the cell and double click on the Label Text object in the tree view. The term Text is assigned inside the cell and the wording of this label can be changed in the properties window (form), on the lower right area of the screen. Once entered, the new information is assigned in the cell both on the working space and the preview window.
