Sheet Counter Object
A Sheet Counter object displays the current sheet number in the cell in "[Sheet] 1 [of] 3" format.
To insert a Sheet Counter object into your template, follow the steps below:
The properties that can be changed for the Sheet Counter Object are the text and font format and must be changed in the General Cell Format on the Design section of the ribbon. It is how-ever, also possible to change the Leading text and separating text that appears within the item and also turn off the page count if needed.
