Image Grids function to allow for images stored within OpenGround Cloud against certain data to be shown on a template.
To insert an Image Grid into your template, follow the steps below:
- Select the cell where you want to insert the Image Grid
- Double-click the Image Grid on the Tree View on the left hand side of the screen
The following properties effect how the Image Grid Functions;
- Category Filter - This allows for filtering of images to show only when they belong to a certain category in OpenGround Cloud. For example, there may be many images attached to a location, but only trial pit photos should be shown.
- Image Width - This is the maximum width that the images should show.
- Image Height - This is the maximum height that the images should show. OpenGround Cloud will fit the image in at the biggest size before it hits the limits of the height or width without skewing the image.
- Image Margins - These effect the spacing that surrounds the images.
- Image Borders - These controls effect the appearance (if any) of the borders that sur-round the image.
- Display Header - This shows the option for showing the Name of the images.
- Image Text Mode - This allows for control of what is showing in the Header (Name, Name and Description etc).
