A header sheet consists solely of a header area and is used to usually present tabular data not found on the Borehole Log i can also include a chart for that single location. As the OpenGround Cloud reporting function allows you to select more than one template for each location type, it is possible to print a header sheet for a bore-hole followed by a borehole log.
