With the introduction of Dynamic Logs, the description bars have had a number of updates to allow for multiple extra functionality when used in conjunction with these.
End Text Mode
When used in conjunction with the End of Borehole text found under the Depth Columns dialogue, allows for selection of a different option based on whether the template is the last page of the whole document (rather than just showing the end of the location).
- ShowOnLastPageOnly – Will show the end of borehole text on the last page in the whole out-put, not on every page showing the location final depth.
- Show – Will show the end of borehole text on every template that shows the location details final depth.
Continuation Text Mode
When used in conjunction with the Next Page text found under the Depth Columns dialogue, allows for selection of a different option based on whether the current page is a page that is a page that has a different template type contained within or not.
- Hide on Split Pages – Stops the Next Page text from appearing on pages where a new template type is shown on that page (if the template changes from one to another on this page, it won’t show the Next Page text).
- Show – Will show the Next Page text on every page, regardless of whether it is a split page or not.
Dynamic Mode
The dynamic mode allows for the selection of what should happen to the description data in the spaces of a page where the current template type does not match the current condition based on your dynamic template expression. There are 4 modes for this:
- (Blank) – Included here as an option and is the default. When no item is selected, description bars will work the same whether the description belongs to the current template or not.
- Replace – Allows for a different expression to be used compared to your default one and allows for a different styling to be applied. This is commonly used if the description should be changed to see next/previous page for example.
- Merge – Works the same way as Replace but combines all of the descriptions into one item instead of separate ones per geology boundary.
- Restyle – Will use the same expression as the default geology description but allows for it to be style in a different way (For example, greying out and italicising the description).
Next Page Text
- Dynamic Next Text – Allows for a different expression to be used to show data when used in conjunction with the Merge and Replace Dynamic modes.
- Dynamic Next Text Font – Allows for a different font to be used when used in conjunction with the Merge and Replace Dynamic modes.
- Dynamic Next Text Size – Allows for a different font size to be used when used in conjunction with the Merge and Replace Dynamic modes.
- Dynamic Next Text Bold – Allows for a different text weight to be used when used in con-junction with the Merge and Replace Dynamic modes.
- Dynamic Next Text Italic – Allows for the text be italicised or not when used in conjunction with the Merge and Replace Dynamic modes.
- Dynamic Next Text Colour – Allows for a different colour to be used when used in conjunction with the Merge and Replace Dynamic modes.
- Dynamic Next Text Alignment – Allows for a different horizontal alignment to be used when used in conjunction with the Merge and Replace Dynamic modes.
Previous Page Text
- Dynamic Previous Text – Allows for a different expression to be used to show data when used in conjunction with the Merge and Replace Dynamic modes.
- Dynamic Previous Text Font – Allows for a different font to be used when used in conjunction with the Merge and Replace Dynamic modes.
- Dynamic Previous Text Size – Allows for a different font size to be used when used in con-junction with the Merge and Replace Dynamic modes.
- Dynamic Previous Text Bold – Allows for a different text weight to be used when used in con-junction with the Merge and Replace Dynamic modes.
- Dynamic Previous Text Italic – Allows for the text be italicised or not when used in conjunction with the Merge and Replace Dynamic modes.
- Dynamic Previous Text Colour – Allows for a different colour to be used when used in con-junction with the Merge and Replace Dynamic modes.
- Dynamic Previous Text Alignment – Allows for a different horizontal alignment to be used when used in conjunction with the Merge and Replace Dynamic modes.
