Setting Up a Dynamic Log
To create a dynamic log, start by selecting the dynamic log template option when creating a new template within the Template Studio interface.
The Dynamic Log Editor window will then appear, allowing for selection of different template types based on different conditions, specified within the expression box (Note that the expression is based on the Group selected). The expression should be written in a way so that a value will be returned when that part of the expression is true. This allows for a more complex expression to be written that handles multiple conditions.
Once an expression has been written, conditions can be added by selecting the Add button. A new item will then appear within the window that allows the Type to be entered. The type is the result of the expression that you want to show a template for. Once a type is selected, a template can be selected for when that result is matched. A strip set can also be selected if the template selected is a master template.
To save the template, select the OK button, where the save template dialogue will then appear.
