Settings
The profile views created with the Interpretation commands are based on the defaults defined in the Settings command. The settings are saved within the current drawing.
Command: HBSI_HBSI_Settings
From the OpenGround Cloud ribbon Interpretation Panel press the Settings icon to display the Interpretation Settings dialog.
Profile View
Projected Strips
Transparency
Profiles:
