Boundary
Adding boundaries to 3D surfaces is an excellent way to control which parts of the surface is dis-played in both 3D but also on profile views. This command helps speed up and automates the adding of boundaries to strata surfaces.
Command: HBSI_CreateBoundary
From the OpenGround Cloud ribbon Interpretation Panel press the Boundary icon, to display the Interpretation Boundary dialog.
