The Interpretation Delete command is a quick way to remove all edits made by an interpretation profile view. By deleting interpretation all elements related to the interpretation will be erased from the drawing, this includes the alignment, profile view, profiles and feature lines
Command: HBSI_DeleteInterpretedSection
From the OpenGround Cloud ribbon Interpretation Panel press the Delete icon.
At the command prompt select the alignment of the Interpretation to delete.
Press Yes to confirm the deletion of the Interpretation, the alignment the profile view, all profiles, feature lines and any edits to the strata surfaces will be removed.
