Geotechnical Legend
The Geotechnical Legend command quickly creates legend tables for the strata in the current project. The legend tables can be created in either model or paper space. The tables created use standard AutoCAD table styles, new styles can be created and edited using the Tablestyles command.
Command: KNX_CreateFenceDiagrams
From the OpenGround Cloud ribbon click Legend to display the Geotechnical Legend dialog.
Geotechnical Legend dialog settings:
